Tagged: 3d, ansys-maxwell-3d, error-code, HF-transformer, maxwell-pemag, troubleshooting
September 13, 2022 at 2:08 pm
bram.oudeaarninkhof
SubscriberI have constructed a planar transformer using PEmag, of which I was able to generate a 2D FEA model. However, when I now try to generate a 3D FEA model I get the following error when the process reaches 'Writing Fields'.
Ansys Electronics Desktop Version 2022.1.0, Build: 2021-11-22 22:18:25
Location: C:\Program Files\AnsysEM\v221\Win64\ansysedt.exe
Description: Error in performing operation.
Line(40): " oModule.CalculatorWrite "J" + CStr(w1 + 1) + "_" + CStr(f + 1) + ".reg", _"[Exiting application]
-- Message Window --
*Global - Messages
[error] Script macro error: Script Error (Code 80070213) in file: C:/[...]/PEmag_ER237.pjt/WriteFields.vbs Description: Error in performing operation. Line(40): " oModule.CalculatorWrite "J" + CStr(w1 + 1) + "_" + CStr(f + 1) + ".reg", _"
I looked into the Help functions of PEmag and browsed the internet to find a solution, unfortunately to no avail. Let me know how I can prevent this error from occuring.
Thank you in advance! -
September 28, 2022 at 7:36 pm
Howard
Ansys EmployeeHello bram.oudeaarninkhof,
Could you try an exmaple in C:\Program Files\AnsysEM\v221\Win64\UPM\Examples\PEmag\ ?
Could you run vb scripting? It seems you might not run the vb scripting.
I also suggest to do perfect installation of EM suite (AEDT).
1). uninstall AEDT completely, and restart computer
2). Turn off anit-virus and firewall, or other policy to block the installation
3). "Run as administrater" to install AEDT
4). Turn on abti-virus and firewall.
HDLI
October 13, 2022 at 2:09 pm
Kili
SubscriberI got the same error and that, even with a perfect installation
October 18, 2022 at 5:49 pm
Howard
Ansys EmployeeHello Kili,
What is the error message?
HDLI
October 20, 2022 at 1:21 pm
Kili
SubscriberHello, the problem is solved, I needed more space on my hard drive. Thank you :)
- Maxwell, HFSS or Q3D?
- Error
2706
2146
1357
1146
462
