pemfc model
    • manikandamaharaj
       iter  continuity  x-velocity  y-velocity  z-velocity      energy          h2          o2         h2o       uds-0       uds-1       uds-2       uds-3     time/iter
             V_cell  = inf (V)      ... V_open    = 10000.000000 ... inf (V)
             I_anode = 0.000000 (A/cm^2) ... I_cathode = 0.000000 (A/cm^2) ... dI_mea = -0.000000 (A/cm^2) ... dI_stk = -0.000000 (A/cm^2)
              Stabilizing x-momentum to enhance linear solver robustness.
              Stabilizing x-momentum using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: x-momentum        Stabilizing y-momentum to enhance linear solver robustness.
              Stabilizing y-momentum using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: y-momentum        Stabilizing z-momentum to enhance linear solver robustness.
              Stabilizing z-momentum using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: z-momentum        Stabilizing pressure correction to enhance linear solver robustness.
              Stabilizing pressure correction using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: pressure correction        Stabilizing species-0 to enhance linear solver robustness.
              Stabilizing species-0 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: species-0        Stabilizing species-1 to enhance linear solver robustness.
              Stabilizing species-1 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: species-1        Stabilizing species-2 to enhance linear solver robustness.
              Stabilizing species-2 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: species-2        Stabilizing temperature to enhance linear solver robustness.
              Stabilizing temperature using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: temperature        Stabilizing uds-0 to enhance linear solver robustness.
              Stabilizing uds-0 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: uds-0        Stabilizing uds-1 to enhance linear solver robustness.
              Stabilizing uds-1 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: uds-1        Stabilizing uds-3 to enhance linear solver robustness.
              Stabilizing uds-3 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: uds-3
      Error at host: floating point exception
      Error at Node 0: floating point exception
      Error at Node 1: floating point exception
      Error at Node 2: floating point exception
      Error at Node 3: floating point exception
      ===============Message from the Cortex Process================================
      Compute processes interrupted. Processing can be resumed.
      Error: floating point exception
      Error Object: #f
    • manikandamaharaj
      n
    • manikandamaharaj
      anyone suggest me idea to solve this issue.n
