PEMFC module in Ansys academic version – error message
    • Ravivarma2012
      I get the following error when i run the calculation. I am using PEMFC model in ansys fluent. I followed all the tutorial steps. When i run the calculation I got the following error and application crashed.
      I am using academic version of ANSYS.
      Ansys.Fluent.Cortex.CortexCommandFailedException: An error occurred in FLUENT when reading data file E:Ansys PEMFCsingle channel tutorialsingle channel tut 1_filesdp0FFF-1FluentFFF-1-00000.dat.gz
         at Ansys.Fluent.Cortex.CortexCommunicator.SendMessage(String msg, String msgKey, String errorMessage, Boolean waitForReply)
         at Ansys.Fluent.FluentCommunicator.ReadData(String fileName)
         at Ansys.Fluent.Data.SolutionData.LoadSolutionPoint(IFullContext context, Int32 iteration)
         at Ansys.Fluent.Data.SolutionData.LoadFiles(IFullContext context)
         at Ansys.Fluent.Data.SolutionData.LaunchFluentAndRead(IFullContext context, Boolean batchMode, Boolean internallyStarted)
         at Ansys.Fluent.Commands.EditCommand.Execute(IFullContext context)
         at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
         at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
         at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
      --- Ansys.Core.Commands.CommandFailedException: An error occurred in FLUENT when reading data file E:Ansys PEMFCsingle channel tutorialsingle channel tut 1_filesdp0FFF-1FluentFFF-1-00000.dat.gz
      CommandName: Fluent.Edit(Container="Solution 1")
         at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
         at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
         at Ansys.Fluent.Commands.EditCommand.InvokeAndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive)
         at Ansys.Fluent.Gui.GuiUtilities.GetLauncherSettingsAndEdit(GuiOperationContext operationContext, DataContainerReference cref, LauncherEditMode editMode)
         at Ansys.Fluent.Gui.OpenInFluentGui.Invoke(GuiOperationContext context)
         at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
         at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly)
      I assume that file exists?
    • Ravivarma2012
      yes. the file exists.
      the following error is displayed before fluent crashes as shown in screenshot below:
      mpt_accept: error acept failed: no such file or directory
    • Ravivarma2012
      Now I get the following error. I have redone the geometry and mesh. Defined the models in fluent as per the tutorial steps. When I run the calculation fluent crashes with the following error:
      Ansys.Fluent.Cortex.CortexCommandFailedException: An error occurred in FLUENT when reading data file E:Ansys PEMFCsingle channel tut ver 26 Novsingle_channel_tut_26_nov_filesdp0FFFFluentSYS-1-00000.dat.gz
      --- Ansys.Core.Commands.CommandFailedException: An error occurred in FLUENT when reading data file E:Ansys PEMFCsingle channel tut ver 26 Novsingle_channel_tut_26_nov_filesdp0FFFFluentSYS-1-00000.dat.gz
      CommandName: Fluent.Edit(Container="Solution")
      Can you try from a path without spaces in the name? Shouldn't be an issue, but may depend on how the commands are stored in the code.
    • Ravivarma2012
      Node 0 Fatal signal raised sig = Segmentation fault
       6a004eb0 CX_Primitive_Error
       efabe10 seh_filter_exe
       6b4f1530 logical_right_shift
       2bc0b0 _C_specific_handler
       111c10e0 _chkstk
       11189ef0 RtlRaiseException
       111bfe40 KiUserExceptionDispatcher
       68ea7a00 Enthalpy
       68e9b730 Update_Properties
       68af9c70 Initialize_Storage
       683ca2e0 init_rsubrs
       6b4dd020 eval
       683c7210 PRF_Command_Start
       683c9a20 PRF_Node_repl
       f537bc0 BaseThreadInitThunk
       1118ceb0 RtlUserThreadStart
      Error [node 0] [time 12/3/19 13:63] Abnormal Exit!
       111c10e0 _chkstk
       68ea7a00 Enthalpy
       6b4dd020 eval
      Error [node 0] [time 12/3/19 13:10:19] Abnormal Exit!
       ac7abe10 seh_filter_exe
       111c10e0 _chkstk
       68ea7a00 Enthalpy
       6b4dd020 eval
      Error [node 0] [time 12/3/19 13:12:55] Abnormal Exit!
       111c10e0 _chkstk
       68ea7a00 Enthalpy
       6b4dd020 eval
      Error [node 0] [time 12/3/19 13:24:13] Abnormal Exit!
       b79e4eb0 CX_Primitive_Error
       b8ed1530 logical_right_shift
       111c10e0 _chkstk
       b6887a00 Enthalpy
       b687b730 Update_Properties
       b64d9c70 Initialize_Storage
       b5daa2e0 init_rsubrs
       b8ebd020 eval
       b5da7210 PRF_Command_Start
       b5da9a20 PRF_Node_repl
      Error [node 0] [time 12/3/19 16:27:9] Abnormal Exit!
       d8bc4eb0 CX_Primitive_Error
       da0b1530 logical_right_shift
       111c10e0 _chkstk
       d7a67a00 Enthalpy
       d7a5b730 Update_Properties
       d76b9c70 Initialize_Storage
       d6f8a2e0 init_rsubrs
       da09d020 eval
       d6f87210 PRF_Command_Start
       d6f89a20 PRF_Node_repl
      Error [node 0] [time 12/4/19 11:29:7] Abnormal Exit!
      Not sure. Check available RAM (and try in serial) then I think you'll need to ask your supervisor to log a support ticket. We're not able to review files on here (export law) but can assist staff from client Universities.
Viewing 6 reply threads
