Penetration Problem in Ansys Workbench
    • Akshay555
      Hi Everyone,
      I am trying to analyse precast arch bridge in ANSYS Workbench. The model needs alternate hinges to be formed and hence a program using ANSYS APDL commands is performed.
      The results showing penetration of the last blocks. Even if the value is small the it is not providing correct stress values.
      Kindly help me with the problem.
      The following program governs the concept:
      *get,myncmls,active,,solu,ncmls
      *if,myncmls,gt,0,then
      cmsel,s,intrados element
      elist
      nsle
      nlist
      seltol,1e-12
      nsel,r,s,1,-1E20,0
      nlist
      *get,numnode,node,,count
      *if,numnode,gt,0,then
      /prep7
      esel,s,TYPE,,241
      edele,all
      ELIST
      /solu
      *else
      /prep7
      esel,s,TYPE,,242
      elist
      edele,all
      /solu
      *endif
      allsel
      *else
      fini
      /config,noeldb,0
      /solu
      *endif
      Penetration at end blocks
Viewing 0 reply threads
