October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeYes. You could read the .rst file and then write a .CDB file. You could then import the .CDB to create the full model in Mechanical. However, this approach will only work in the /UNITS command is written to the .rst file.
October 4, 2017 at 2:39 pm
pgl
Ansys EmployeeIs it possible to perform submodeling using only the .rst file from a "coarse" model (i.e., no coarse.db)?’
2120
1347
1118
461
