December 18, 2022 at 7:43 am
faridnugroho21
SubscriberCurrently I'm working on a project which optimized a Topside Structure of a offshore platform. The topside is pretty big, which I can't analyze it with student license. So I use submodelling technique to optimized it at partucular part. But, I got a problem when the topology optimization didn't show the result like in the picture. So, is it really can be done with submodelling or not? Or I did something wrong?
thanks in advance -
December 20, 2022 at 4:49 pm
John Doyle
Ansys EmployeeYou can certainly do a topology optimization on a particular part or subset of a larger part. In fact, that makes a lot of sense, even if you have lots of computing power at your disposal. With regards to the image you are sharing, try zooming out.
I see something in the lower corner of the screen, just above the table. See my screen capture below. What is this?
December 24, 2022 at 4:01 am
- can’t login to cloud acccess using the same email on the independent campus web
- Selamat Datang
- Rosette Gauge Purpose
- Web Course Ansys
- Brake Pad Analysis Simulation Problem
- Cell Phone Drop Test Simulation Problem
- lumbar motions simulations problem- in solid mechanic
- Lumbar Motion Simulation – Coding part
- Meshing Problem in Helicopter Pitch Arm
- Could anyone have solution to fix it? Thanks
2706
2142
1355
1144
462
