September 20, 2018 at 6:54 pm
rounaksingh
SubscriberHi,
I am trying to simulate a large wire grid. However, it is not possible to simulate the wire grid at once due to colossal mesh. Therefore, I am trying to use the periodic boundaries (master-slave and floquet port). I am able to generate plane waves at different incident angles. However, my aim is to have a dipole-like incidence. Also, the dipole is excited very near to the wire grid.
Please let me know if you have any ideas on how to simulate the structure.
Thanks!
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
