Preprocessing
Preprocessing
Periodic Mesh in Workbench
    • Eren Açar
      Hello all,
      I want to create periodic mesh for this geometry (cube with hole). Dimensions of th cube are 1*1*1 mm and diameter of the hole is 0.5mm. Is it possible to create periodic mesh for Static Structural Analysis in Workbench? I tried face mesh and edge sizing together and obtained the mesh that I attached, but I am not sure about its periodicity.
      You're looking for Match Control, and may need to pair up any/all faces that you want to make periodic. However, you may want to check in Mechanical to see what the boundary options are: do you need periodic?
