phase change materials in construction by Ansys Fluent
    • Jonn
      good morning
      I need help if possible
      I have research to study phase change materials used in construction by Ansys Fluent
      Study of the temperature change of the inner side of the wall The wall consists of a layer of insulation , brick and a layer of phase change materials on the inner side
    • Karthik R
      Administrator
      Hello Since you are running a transient simulation, I'd suggest that you pick your time-step size in such a way that the CFL number is close to 1. CFL number calculation depends on the velocity scales and grid sizes used in your problem.
      Regarding the residuals, we recommend that you at least converge the solution by 3 orders of magnitude. Since this is a transient solution, attempting to converge more than 3 orders of magnitude might increase your computational time.
      Karthik
    • Jonn
      Hello
      Thanks for your reply. And sorry to bother you again
      So for the time-step size I can give 1s, The goal of my simulation is to follow the evolution of the temperature of the wall over a period of 7 hours, giving one second for the size of the time step and 25000 for the number of time steps but for the residual monitors I give 10e-7 or 10e-9 and I find the same problem the solution stops quickly problem of convergence of solution . see figure case 1
      But when I cancel the convergence, it gives about 10-14, 10-15 and the computation takes a lot of time, see figure case 2
      Should I increase the value of residual monitors? Or could the problem be in the initial conditions?
      The zero values for the continuity and momentum equations suggests something odd is going on. How is the PCM material zone defined?
    • Jonn
      Hello Mr. Rob
      Zero values of continuity and momentum I think is because gravitational force is neglected. Because when I enter the value of the gravitational force, I get the following results
      Which suggests that something is moving. What does the flow field look like?
    • Jonn
      I think because the inlet temperature is variable !!
Viewing 6 reply threads
