May 2, 2022 at 3:31 pm
ha_nguyen3
SubscriberHello,
On my HFSS model, I calculated the total current delivered to the object by using fields calculator:
Intergrate(Surface(Object)), Mag(Real(
))) Let say the result is 50mA. I assume that if the voltage and current are in phase, 50mA is what I need. If they are out of phase, I need more than 50mA to power the system.
How do I find out if the voltage and current are in phase or out of phase in HFSS? (plot?, calculation of the angle?)
Thank you.
May 13, 2022 at 3:52 pmPraneeth
Did you try assigning output variables. Please go through this link - Ansys Electronics 2022 R1 - Post Processing and Generating Reports.
Then using this variables, you can either calculate or plot the phase of both voltage and current.
All the very best Praneeth.
May 15, 2022 at 7:55 amphuonganhlovely.me
Subscriberwhat do you mean the voltage and current are in phase?
May 18, 2022 at 5:58 pmha_nguyen3
Is there other way to access the page? The link directed me to the login page and asked me to complete the registration. After I filled out everything and submitted, I got the following message. Then I clicked on the login page and had to fill out again. The message popped up again, and thus I couldn't access the page.
Thank you.
Hope this helps.
https://engineer-educators.com/topic/phase-of-current-and-voltage-in-reactive-circuits/
https://www.electrical4u.net/electrical-basic/phasephase-anglephase-difference-easy-understanding/
September 7, 2022 at 10:51 am
Praneeth
Ansys EmployeeHi,
You would be able to access this link by logging in with the credentials of the academic license.
Best regards,
Praneeth.
May 31, 2022 at 1:14 pmphuonganhlovely.me
Subscriber-
September 7, 2022 at 10:49 am
Praneeth
Ansys EmployeeHi,
It looks like your question is different from the original thread. Please post your question as a new thread to help us serve you better.
All the very best,
Praneeth.
Viewing 4 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1815
1236
594
