June 28, 2022 at 10:56 am
Catherine.antipuesto
SubscriberHello! I tried plotting the wavelength vs phase graph with the script:
E=getresult("through","E");
Ex=pinch(E.Ex);
Ey=pinch(E.Ey);
Ez=pinch(E.Ez);
xphase=angle(Ex);
f = getdata("through","f");
plot(c/f,xphase);
However, it says:
Error: line 7: y matrix must be same length as x matrixHow do I fix this?
Why is my E-field matrix [69, 500] while my wavelength is ? What does this mean?
Thank you so much!
June 28, 2022 at 7:36 pm
Guilin Sun
Ansys EmployeeLine 7 is this:
plot(c/f,xphase);
It will only work if the monitor is a point!
To know the frequency points, you can use
nf=length(f);
Since usually the frequency point is in the last dimension, in your case, it is 500.
The other number 69 is the space point.
Since now it is 2D matrix, you will need to image it.
If you only want to plot phase vs f at given space point, you have to specify the space point, eg
mm=30; $the 30th space point
plot(c/f,pinch(xphase(mm,:)) )
please try.
In addition, since now you know more about the phase extraction, please review the previous posts you got replied. -
June 30, 2022 at 10:47 am
SubscriberThank you so much for this! Why is the graph different at different space points? What is the implications of space points? Thank you again! :)
- Error on Lumerical device
3670
2552
1751
1226
584
