Photonics
Photonics
Phase Graph Lumerical MODE
    • Catherine.antipuesto
      Hi! I am new to Lumerical and I would just like to ask how to obtain the wavelength vs phase graph. Thank you! :)
    • Guilin Sun
      There are 2 steps using script to get the phase:
      1: get the field components. As you know, the phase is associated with Ex,Ey, Ez (or H components). So you can use
      E=getresult("monitor","E");
      Ex=E.Ex;
      Ey=E.Ey;
      Ez=E.Ez;
      similarly you can get x,y,z and f.
      2: get the phase. for example for Ex, you can write
      xphase=angle(Ex);
      which will be a function of xyz and f.
    • Guilin Sun
      additional information:
      1: you can use Ex=getdata("monitor","EX") if you know you want Ex
      2: you can use pinch to remove singular dimension: https://optics.ansys.com/hc/en-us/articles/360034405674-pinch-Script-command
      Thank you for this! How can I plot this? Thank you!
    • Guilin Sun
      plot is only for 1D data. eg, plot(x,y,”x”,”y”,”y(x)”.
      image is for 2D data.
      please search plot/image in Lumerical website  https://optics.ansys.com/hc/en-us/articles/360034410474-plot-Script-command
      depending on the dimension of phase, please choose proper script to plot it.
      Hello! I tried plotting it with the script:
      E=getresult("through","E");
      Ex=pinch(E.Ex);
      Ey=pinch(E.Ey);
      Ez=pinch(E.Ez);
      xphase=angle(Ex);
      f = getdata("through","f");
      plot(c/f,xphase);
      However, it says:
      Error:
      line 7: y matrix must be same length as x matrix
      How do I fix this?
      Why is my E-field matrix [69, 500]? What does this mean?
      Thank you so much!
    • Guilin Sun
      This question has been replied in another post.
Viewing 6 reply threads
