August 24, 2022 at 12:21 pm
mhu
SubscriberHello,
At photodiode design, during FDTD analysis if my input optical source has a wavelength range not a fixed wavelength. So from CHARGE simulation the output current I am getting is proportional to the input power integrated over the whole wavelength range. If I am understanding correctly the software is doing the same. Isn't it?
August 24, 2022 at 10:08 pm
Guilin Sun
Ansys EmployeeYou are right. It is not directly from the software. Instead, it is from post processing in the analysis group in FDTD. BY default it integrates all the powers for the whole source spectrum range. If you want to get wavelength-dependent I-V or other quantities from CHARGE, you can modify the FDTD analysis group not to integrate.
- Error on Lumerical device
2706
2146
1357
1148
462
