August 22, 2022 at 9:19 am
mhu
SubscriberHello,
In my designed vertical photodiode, I used a customized mode source as input with a wavelength range from 0.9 um to 1.3 um and having two peaks; one at 1 um and another peak at 1.2 um. Then I calculated electron hole pair generation rate from FDTD simulation and applied it at Charge simulation.
My question is that, since my input source has a wavelength range and having two peaks not only one center wavelength. How can I get my photodiode's current over this wavelength range? as I dont know for which wavelength perticularly i'm getting the I-V curve of the photodiode.
August 22, 2022 at 6:03 pm
Guilin Sun
Ansys EmployeeBy default, you get the averaged result for the given bandwidth, since the power is integrated over the bandwith. If you want to get result with respect to each wavelength, please modify the FDTD Analysis group to get the wavelength dependent power and the generated e-h pairs.
August 22, 2022 at 7:32 pm
mhu
SubscriberThank you for your answer!
- Error on Lumerical device
2720
2146
1357
1150
462
