December 31, 2022 at 4:42 pm
Fabian Scr
SubscriberHello
Can the Included Phyton Script edit the file by Opening?
Open the File -> Start Phyton Script Automatic to Write a Yellow Text in the Position X10,Y10 the text is in Description of the Document
January 2, 2023 at 12:58 pm
Aniket
Ansys EmployeeCan you please explain your question in some more detail? Did you mean to attach images inline?
-Aniket
January 4, 2023 at 5:03 pm
January 4, 2023 at 5:47 pm
Aniket
Ansys EmployeeUnfortunately, your question is still not clear to me, do you want to create a note using a script? If yes, you can check the below script:
from SpaceClaim.Api.V22 import Notefrom SpaceClaim.Api.V22 import LocationPointsel = Selection.GetActive()if sel.Evaluations.Count >0:plane = DatumPlaneCreator.CreatePlaneFromSelection(sel)datumP = DatumPlane.Create(GetActivePart(), "myPlane", plane)location =LocationPoint.CenterNote.Create(datumP, PointUV.Origin, location, 0.005, "my Note")If this is not what you need, please explain your question in more details.
-Aniket
January 4, 2023 at 7:06 pm
Fabian Scr
Subscriberi want create a note with the Text in Description from the Spaceclaim file Characteristics, the note is mirrored and the Position is in the Corner
This Automatic by Open the File (Run the Phyton Script by Open a File)
January 5, 2023 at 11:15 am
Aniket
Ansys Employee -
January 16, 2023 at 7:20 pm
Fabian Scr
SubscriberHalf :-) can i Start phyton Script automatic by Open a Spaceclaim File?
January 17, 2023 at 4:13 am
Aniket
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2142
1355
1144
462
