TAGGED: iterate, iteration, iterations, phyton, spaceclaim
September 6, 2023 at 12:32 pm
Luis Rodriguez
SubscriberHello, I made a script to make variations of a piece. I need to iterate the pieces 500 pieces, in size (height and length), and then record the data of weights and center of mass in an excel table. I have thought of using python with an excel table of 500 lines (width and height) so that spaceclaim makes each iteration automatically and later records the result of center of mass and total weight in the same excel or csv sheet.
***Do you know of any model or manual to follow an example or something similar?*** -
September 7, 2023 at 8:43 am
Subashni Ravichandran
Forum ModeratorHello Luis,
Let me check with my team to for any inputs on this and get back to you.
September 12, 2023 at 3:02 pm
Luis Rodriguez
SubscriberSubashni, Some answer?? regards ..!!
September 14, 2023 at 3:35 pm
This can be donw in SpaceClaim. Please refer the below documetation link for more information on this.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7592
4440
2953
1427
1322
