May 12, 2023 at 12:16 pm
Eglantine PERRON
SubscriberHi !
I would like to study the power integrity of an evaluation board with PI advisor.
For the step 1 in the PI Advisor Wizard they ask to determine the VRM parameters (ESL/ESR) but I can't find any information about it on the datasheet. I work on the PolarFire MPF300 (https://www.microchip.com/en-us/development-tool/MPF300-EVAL-KIT) and the core power signal. Do you have any idea where I could find the answer ?Thank you.
May 12, 2023 at 6:56 pm
Nathan Bertrand
Ansys EmployeeHello, you won’t be able to find the ESL/ESR from an eval kit spec sheet. You’ll need to find the data sheet on the VRD (Voltage Regulation Device). See Ansys Learning Hub: SIwave_Intro_2019R1_Student_Files_21-12.zip (sapjam.com) workshop 3.3 for more information on PI Advisor.
- Maxwell, HFSS or Q3D?
- Error
5268
3299
2469
