Piezo-Circuit, how to add the APDL code in work bench
    • Mona Yadi
      I hope you all are fine.
      I took a long time to connect the equivalent circuit of the piezo material (Quartz) to its electrodes (attached on both sides of the quartz), gave it sine voltage, and did a harmonic analysis to see the amplitude of piezo oscillation in the specific range of frequency. I added the CAD data directly to the workbench and added the APDL commands (attached) to the modal analysis (added before the harmonic analysis). Based on the errors I receive " Element 18590 does not have all of its required nodes defined.  The E command is aborted" I am guessing that the problem is with nodes and elements that I introduced. It would be really appreciated if you can help me with this issue.
      I attached the equivalent circuit and the APDL codes, Thanks in advance for your help.
      cmsel, S, Base
      nsle, S, All
      et,1,SOLID226,1001
      *get,Epz,elem,,count ! Get the number of solid elements
      cmsel, S, POS
      nsle, S, All
      cp,1,volt,all
      *get,POS,node,0,num,min ! get master node on bottom electrode
      cmsel, S, GND
      nsle, S, All
      cp,2,volt,all
      *get,GND,node,0,num,min ! get master node on top electrode
      d,GND,volt,0 ! ground bottom electrode
      d,POS,volt,1
      fini
      /prep7
      ! Element types
      et,62,CIRCU94,0 ! R1
      et,63,CIRCU94,2 ! C1
      et,64,CIRCU94,1 ! L1
      et,65,CIRCU94,2 ! C0
      et,66,CIRCU94,4 ! C0
      ! Real constants
      Vmax = 1
      R1 = 22439.55
      L1 = 6405.34626
      C1 = 3.69e-14
      C0 = 1.82e-12
      r,1, Vmax
      r,2, R1
      r,3, L1
      r,4, C1
      r,5, C0
      ! Nodes and elements
      n,1,0,0
      n,2,0,1
      type,65 $ real, 5
      e, 2, 1
      type,66 $ real, 1
      e, 1, 2 ! Voltage source
      e, POS, GND ! Voltage source feeding
      n,3,1,1/3
      n,4,1,2/3
      type,62 $ real, 2
      e, 1, 3
      type,64 $ real, 3
      e, 3, 4
      type,63 $ real, 4
      e, 4, 2
      fini
    • Erik Kostson
      Yes, the nodes 1,2,3,4 allready exists in the workbench mesh/model so can not be used again (find the last node number and add 1 and use that in the new nodes).
      You can see in VM237 how to use circu94 with solid226 piezo – in there you will see that he pzt starts from node10 (
      NUMSTR,NODE,10),
      then it is ok to define N,1 and so on since these nodes do not exist.
      Also look for posts in the forum (e.g., : https://forum.ansys.com/forums/topic/ansys-2021-workbench-piezoelectric-analysis-add-resistor/)
      All the best
      Erik
    • Bill Bulat
      As an alternative to Erik's suggestion, you can interrogate the MAPDL database for the highest numbered node that exists in the model. Let's call it NMAX. This command:
      *get,NMAX,node,,num,max
      will define parameter NMAX and set its value to the highest numbered node in the model. You can then create additional nodes to construct the CIRCU94 elements:
      n,NMAX+1,xlocation,ylocation,zlocation
      n,NMAX+2,xlocation,ylocation,zlocation
      By the way, APDL is not case sensitive.
      Kind regards,
      Bill
