November 12, 2018 at 7:30 pm
AYIR
SubscriberHi,
I am trying to use PiezoAndMems ACT extension to solve a thermoelectric structural analysis on a deforming contact (contact size changes by both pressure and temperature). I encountered two problems:
1- Every time that I close the file and reopen it again the workbench does not recognize the features I used from the ACT extension! (The ACT extension is set to load as default).
2- Every time I add the voltage to the analysis it cannot be solved and it proposes changing a line in the main code! I have done the same simulation (at least for the thermoelectric part) in the thermal-electric analysis system of Workbench and it works fine!
I would appreciate it if someone could help me with these.
Thanks,
November 12, 2018 at 8:19 pm
Karthik R
AdministratorHello Ayir,
I'm moving this question to structural mechanics thread for better visibility. Hopefully, structural mechanics experts can answer this one for you.
Thank you.
Best Regards,
Karthik
November 13, 2018 at 7:46 pm
Sandeep Medikonda
Ansys EmployeeAyir,
Is loading your ACT extension every time you open the model working?
As for the issue with the voltage BC, what is the complete text of the message that proposes changing a line in the main code? Can you post a snapshot?
Sandeep -
November 13, 2018 at 9:37 pm
AYIR
SubscriberHi Sandeep,
I set the ACT extension to "load as default" mode so it is loaded every time I open the model.
Here is one of the errors I got:
*** ERROR *** CP = 39.719 TIME= 16:11:48
Degree of freedom VOLT at node 14921 is both in MPC contact elements
and a slave degree of freedom of coupled set 2, which may cause a
problem. Please replace the command:
CP,2,VOLT,12421,14921
with the command:
CE,next,0.0,14921,VOLT,-1.0,12421,VOLT,1.0.
The rest of the errors are similar to this one.
Al
2120
1345
1118
461
