March 6, 2023 at 4:22 pm
Matthew Davenport
SubscriberHello,
I am working to create a Piezoelectric Birmorph Actuator that models a cantileaver beam with a substrate twice as thick as the indivdual layers of Piezoelectric materials on the top and bottom surface. The cantlieaver beam is meant to be an extreme condition where the actuators and substrate are very long compared to their thickness, i.e. 10-40 meters long while 1 to 2 mm thick.
This code is modified from the Ansys APDL manual example of a Piezoelectric Bimorph. I am able to get the model to work fairly well when the lengths are less than or equal to 1 meter, however past this length, I find errors in pairing electrodes across the top and bottom materials.
I do not entirely understand all line items in the code which I modified from the manual, however I believe the areas and meshing are not the issue, but rather something with how I am assigning the electrodes to the top surface. Any help or advice is greeatly appreciated!
/batch,list
/title, Static Analysis of a Piezoelectric Bimorph Beam
/nopr
/com,
/PREP7
! Define problem parameters
! - Geometry
L=.1 ! Length, m
H=0.5e-3 ! One-layer thickness, m
Ls = .1
Hs = 1e-3
Htop = Hs+H
! - Loading
V=100 ! Electrode voltage, Volt
Uy=10.e-3 ! Tip displacement, m
! - Material properties for PVDF
E1=2.0e9 ! Young's modulus, N/m^2
NU12=0.29 ! Poisson's ratio
G12=0.775e9 ! Shear modulus, N/m^2
d31=2.2e-11 ! Piezoelectric strain coefficients, C/N
d32=0.3e-11
d33=-3.0e-11
ept33=12 ! Relative permittivity at constant stress
! Finite element model of the piezoelectric bimorph beam
local,11 ! Coord. system for lower layer: polar axis +Y
local,12,,,,,180 ! Coord. system for upper layer: polar axis -Y
csys,11 ! Activate coord. system 11
rect,0,L,-H,0 ! Create area for lower layer
rect,0,Ls,0,Hs
rect,0,L, Hs,Htop ! Create area for upper layer
aglue,all ! Glue layers
esize,H ! Specify the element length
et,1,PLANE223,1001,,0 ! 2-D piezoelectric element, plane stress
et,2,PLANE183
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,2,,228e9
MPDATA,PRXY,2,,0.3
tb,ANEL,1,,,1 ! Elastic compliance matrix
tbda,1,1/E1,-NU12/E1,-NU12/E1
tbda,7,1/E1,-NU12/E1
tbda,12,1/E1
tbda,16,1/G12
tb,PIEZ,1,,,1 ! Piezoelectric strain matrix
tbda,2,d31
tbda,5,d33
tbda,8,d32
tb,DPER,1,,,1 ! Permittivity at constant stress
tbdata,1,ept33,ept33
tblist,all ! List input and converted material matrices
amesh,all
nsel,s,loc,x,L
*get,ntip,node,0,num,min ! Get master node at beam tip
nelec = 100 ! Number of electrodes on top surface
*dim,ntop,array,nelec
l1 = 0 ! Initialize electrode locations
l2 = L/nelec
*do,i,1,nelec ! Define electrodes on top surface
nsel,s,loc,y,Htop
nsel,r,loc,x,l1,l2
cp,i,volt,all
*get,ntop(i),node,0,num,min ! Get master node on top electrode
l1 = l2 + Htop/10 ! Update electrode location
l2 = l2 + L/nelec
*enddo
nsel,s,loc,y,-H ! Define bottom electrode
d,all,volt,0 ! Ground bottom electrode
nsel,s,loc,x,0 ! Clamp left end of bimorph
d,all,ux,0,,,,uy
nsel,all
fini
/SOLU ! Actuator simulation
antype,static ! Static analysis
*do,i,1,nelec
d,ntop(i),volt,V ! Apply voltages to top electrodes
*enddo solve
solve
fini
/SOLU ! Sensor simulation
March 6, 2023 at 4:26 pm
Erik Kostson
Ansys EmployeeHi
I would recommend to use WB coupled field harmonic or static system.
If you want to use an example though in APDL there are some in our help manual - coupled field analysis.
All the best
Erik
March 6, 2023 at 4:48 pm
Matthew Davenport
SubscriberHi Erik,
Thank you for your response, I have been using the 2.15 example of a Bimorph in the APDL Coupeled Field Analysis Guide, which this code is based off of. Creating and selecting electrode positions across the top and bottom surfaces seems to be where this code breaks. Any advice on how to use the nsel command?
Thank you,
March 6, 2023 at 5:23 pm
Erik Kostson
Ansys EmployeeHi
Is this the exact same 2.15 example as in the apdl manual? if it is it should run
Or is this example something different and not our 2.15 example?
All the best
Erik
March 6, 2023 at 5:32 pm
Matthew Davenport
SubscriberHi Erik,
This is based off that example, but I have made modifications to represent my problem constraints, which include a substrate material between the actuating surfaces, and different geometry.
The example straight from the manual runs great, but the modifications I have made are resulting in strange errors, and I am unsure how.
March 7, 2023 at 8:32 am
Erik Kostson
Ansys EmployeeHello
There is an error in the line:
*enddo solve is wrong and should be:
*enddo solve
Another things is that the pol. direction is opposite in the 2.15 example while you have the same:The polarization which is given by these lines and in combination with the material properties given (which are relative the element system):
local,11 ! Coord. system for lower layer: polar axis +Y local,12,,,,,180 ! Coord. system for upper layer: polar axis -Y
type,1 $ esys,11 amesh,1 ! Generate mesh within the lower layer type,1 $ esys,12 amesh,3 ! Generate mesh within the upper layer
Erik
March 15, 2023 at 12:43 pm
Matthew Davenport
SubscriberHi Erik, thank you for the clarification!
Regarding the polarization, are you stating that my code is now, the polarization of the material set by the mat properties is opposite the polarization direction set by the coord system? If so, how could I correct the coordinate system lines of code?
March 15, 2023 at 12:47 pm
Matthew Davenport
SubscriberAnd a follow up question as I am new to coupeled field elements in ADPL, should the top piezo and bottom piezo be polarized in opposite directions? I am also attempting to create a 3D bimorph cantileaver beam using 226 and 186 elements. Is there a specific way I should handle the polarization and voltages aross the top and bottom piezo volumes in that example?
March 15, 2023 at 12:51 pm
Erik Kostson
Ansys EmployeeHi
In the 2.15 example the polarization is opposite on top and bottom piezo patch (so the polarization is given by the material property definition TB command and the element system esys as shown below):
3850
2613
1853
1246
600
