February 5, 2023 at 11:58 pm
Mahmoud Nassar
SubscriberHi,
I'm trying to simulate a PZT using ANSYS mechanical workbench.
I have downloaded the ACT successfully. Now I am trying to duplicate the results for the “Piezoelectric fan” found in the documentation, but I failed. I am stuck for a long time and I do not know what I am doing wrong?!!!
For Example:
In the modal analysis, the answer is [Mode1 = 60.142 HZ, Mode2 = 349.28 HZ]. For me, I get [Mode1 = 59.949 HZ, Mode2 = 333.12 Hz]
Further, for the frequency response, I get a completely different plot than the one in the documentation and have no idea why !!!!
Note: I am using ANSYS 2020
Any help will be appreciated
February 6, 2023 at 9:00 am
Erik Kostson
Ansys EmployeeHi
THe act extension is not supported and developed longer.
Use the coupled field modal and harmonic to analyse Piezoelectric+structure+acoustics (if needed).
For an example see technology demo or showcase TD39: Wire Bonding with Ultrasonic Transducer
All the best
Erik
February 6, 2023 at 2:11 pm
Mahmoud Nassar
SubscriberThank you for your reply
My goal was to solve the piezoelectric in an FSI problem (FlUENT+ Transient Structure). So, I had first to validate an ANSYS problem (Modal + Harmonic).
To be on the same page, do you mean this video where he is using the ACT (Piezo & Mems):
https://www.youtube.com/watch?v=TuQGOMnDtDI
or am I wrong ?!
Thank you
February 6, 2023 at 2:22 pm
Erik Kostson
Ansys EmployeeIt is perhaps the same or similar model – but what I refer to is td39 in the help manual (search for that title in the ansys help manual: Wire Bonding with Ultrasonic Transducer) and using the native coupled field system – as we said the act mems is not supported anymore by us.
All the best
Erik
February 6, 2023 at 6:27 pm
Mahmoud Nassar
SubscriberOh, I see that now
Thank you, that is really helpful.
February 13, 2023 at 11:34 pm
Mahmoud Nassar
Subscribercan we use a Coupled Field Transient (Piezoelectric with transient structure) in system coupling with FLUENT?!!!
I am trying to do that but I keep getting errors, the coupling is not working!! -
February 14, 2023 at 7:28 am
Erik Kostson
Ansys EmployeeHi
It is there and possible to use from 2023 R1.
See the 2023 R1 help manual under the system coupling user guid and section:
Supported Coupling Participants for System Coupling in Workbench
All the best
Erik
3251
2443
