November 5, 2018 at 6:47 pm
Ankitha
SubscriberHello,
I want to know the procedure to analyse a single pile interaction with the soil , having a pile cap 1 foot embedment length.
November 5, 2018 at 11:16 pm
March 28, 2019 at 7:10 pm
Aliyu
SubscriberHi Ankitha, I am battling the same problem at the moment. Were you able to find the solution to the problem above? Also, if anyone else can help with modelling pile-soil interacation in ansys workbench, it'd be greatly appreciated. Thanks -
March 31, 2020 at 12:33 pm
Ankitha
SubscriberHello Aliyu,
I ma sorry I saw your post late. Did you try to solve your issue? I got the analysis for single layers of the soil and now I am working with multi layers. let me know if I can be of any help.
Thanks.
- I’m a starter
- YouTube tutorial files
- Fluid Flow – Lid Driven Cavity
- Thermal – Heat Conduction in a Cylinder
- Fluid Flow – Turbulent Flow Over a Backward Facing Step
- Fluid Flow – Taylor-Couette Flow between Rotating Cylinders
- The project files directory doesn’t exist
- Magnetics-Permanent Magnetic Circuit with Air Gap
- Process ‘3dedy’ terminated abnormally. It may have run out of memory or could have been killed by..
- vibration
2688
2138
1355
1140
462
