Discovery Import
Discovery Import
Pin positions on the unfold metal sheet
    • Piotr Pietraszek
      on the unfold metal sheet, I have to put symbol like that:
      This symbol have to indicate middle of this welded pins, it should be on separate layer with yellow color, and it should be put in to dxf/dwg file when I'm saving Unfold to dxf/dwg.
      How can I do that in the easy way ?
      Bellow I'm sending example to explain what I mean:
    • Devendra Badgujar
      Hi Piotr Pietraszek Izabella Pietra
      I will look into this and get back to you.
    • Devendra Badgujar
      Please can you share this sheet metal file with welded pins in it with me, I will try it at my end and let you know.
      Regards.
      • Piotr Pietraszek
        🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
        Devendra Badgujar
        Hi, the file is in attachement.
        Regards
    • Devendra Badgujar
      You can add that symbol to indicate pin position from Detail>Annotations>Center line.
      Currently it is not possible add a color to it using separate layer.
      Please add this to the ideas section Ansys SpaceClaim Ideas - Ideas - Ansys Discovery Forum for this to be added.
      Regards
    • Piotr Pietraszek
      Ok,
      this way is ok, but it couse another problem :)
      I have set sheet metal export like below:
      If I attache unfold to drawing sheet, I can't save it to dxf without bend extent lines.
      If I save unfold to dxf directly everything work ok.
      I'm attaching real example file.
      It include model, unfold, drawing sheet.
      If I'm saving unfold to dxf result is ok - there are no bend extent lines, but also I can't indicate
      center line of pins:
      If i'm saving sheet to dxf, there are center line of pins, but there are bende extent lines:
      But ... this is not rule ... sometimes it is possible to save without these lines - I do not know what it depends on, example (it work on the same settings):
      • Devendra Badgujar
        I will check and get back to you on this.
    • Devendra Badgujar
      Please turn off the Show Flat Bend Extents option, to save without these lines but with the center line of pin.
Viewing 5 reply threads
