November 16, 2018 at 11:10 am
ammorey
evening to all of you , hope that all are fine
what Im doing here is an analysis for a pipe which contain surface crack. The pipe here under internal pressure, I fixed the both ends so it will not move in any direction and applied the internal pressure, but after doing the simulation the pipe deformed in the way as showed in the picture above which is not supposed to deform like that ! as you see above the pipe got something like swelling which can be noticed with the lite color.. I googled this problem but what I got this deformation occurred due wrong constraint or the model has more degree of DOFs, could you just guide me how to model or what is the suitable constraints required for this model. I'm using ansys workbench 19.0.
I tried also to decrease the value of the internal pressure and the results (for the pipe deformation ) are same .
Thanks in advance
November 16, 2018 at 11:19 am
Aniket
ANSYS employees cannot download attachments in the post, can you please add some inline images? What do you mean by it is not supposed to deform this way?
Are you following any tutorial?
November 16, 2018 at 12:18 pm
ammorey
Subscriberhello Aniket
thanks for your reply , I attached the photo again . for the second part of your reply about what I mean I think it will be clear with the photo .
thanks again
November 16, 2018 at 1:10 pm
Keyur Kanade
Ansys EmployeePlease insert images.
Moving this thread to sturctural mechanics category for better response.
November 16, 2018 at 2:29 pm
Aniket
Ansys EmployeeHi ammorey,
Sorry, your question is still not clear to me as I am unable to understand the issue from the image that you have posted. Please provide additional details to help you better with this question.
November 16, 2018 at 5:53 pm
ammorey
hi Aniket ,
thanks for your reply .. what Im doing here is analysis for pipe which contain surface crack. The pipe here under internal pressure, I fixed the both ends so it will not move in any direction and applied the internal pressure, but after doing the simulation the pipe deformed in the way as showed in the picture above which is not supposed to deform like that ! as you see above the pipe got something like swelling which can be noticed with the lite color . So what Im expecting now is the problem with constraint that I applied or there is something else. I wish that everything has been clarified.
Thank you so much
November 19, 2018 at 10:19 am
Aniket
Ansys EmployeeWhat is the result is scoped to? How is the crack modeled?
What is the total deformation of the entire pipe? What is result display scale? Can you insert image of entire Mechanical window?
You have fixed the ends, and applied internal pressure, why do think that the pipe won't swell in this condition? -
November 19, 2018 at 11:56 am
ammorey
SubscriberHi Aniket and thanks for your reply;
linear Elastic if I did not misunderstand you ..
I used semi- elliptical crack from fracture icon
Iam looking for the value of the stress intensity factor at the crack front
I don't know exactly what it is; because Im not that much familiar with Ansys workbench may be this one ( 1.1e+003 (Auto Scale))
Yes , normally any pipe with any internal pressure should not deform like that , the pipe deform even with very low pressure ..
I think the problem with model which has degree of freedom higher than what my problem should have .. what I did is draw to circles then I extruded it to the desired length . Is it wrong ?
Thanks Again
November 20, 2018 at 12:21 pm
Aniket
I believe this is due to the fact that the result scale is auto and it is a very high number. Please change it to true scale and see if that looks the way you would expect.
November 20, 2018 at 5:06 pm
2104
1327
1110
461
