pipe extension with different diameter
    • Amir
      Hello everyone, how can I model pipe extension with different diameter in design modeler?
      I am trying to design this pipe with some thickness (1mm) as solid, and fill it with fluid.
      for the fluid domain I would create cylinders and connect them toghether using boolean option, but I do not know what option to use to model the pipe first.
      Thanks
      Do you need to include the solid part or can you just model the fluid domain?
      • Amir
        I needed to include the solid part as well and I was able to model the geometry by using this/surface tool. Thanks Rob.
