November 30, 2020 at 10:18 am
Nguyen Van Toan
SubscriberHi everyone,
When we simulate multiphase flow using VOF model, what the Pressure-Velocity Coupling Method is appropriate? PISO or Coupled? Which is faster? And for FSI simulation, is there only Coupled available?
Thank you so much!
November 30, 2020 at 10:34 amDrAmine
Ansys EmployeeA general recommendation in Fluent Multiphase whenever time step size is small PISO will perform better from computational time perspective. Though, I saw a lot of cases running much more efficient using Coupled method . So at the end you need to select the method which works better for you.
Viewing 1 reply thread- The topic ‘PISO or Coupled (VOF)’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
