Piston Dynamic Mesh Problem
    • barteo
      I am trying to simulate a simple piston flow, pushing the fluid out from a nozzle at the end. See the attached image. The orange, blue, purple, and yellow colors represent the moving wall (20 mm), axis (118 mm), cylinder wall (100 mm), an orifice at the end (8 mm), respectively.
      I am using a laminar, axisymmetric model with VoF (air and liquid) where the liquid is a non-Newtonian fluid with known rheological parameters.
      The problem I am facing is that I cannot make the wall move.
      I am using a profile file (.prof) that had the following text:
      ((x_motion 2 point)
      (time 0 10)
      (v_x 0.001 0.001))
      This file is defined for the moving wall (rigid body), as well as the cylinder wall (deformation)
      Can you please help? What am I doing wrong? What are your recommendations?
      Thanks,
      Baran
    • Kishan Konannavar
      Hello
      Ansys staff are not permitted to download attachments from the forum, can you please insert the image directly into your post?
      Regards
      Kishan
    • barteo
      Hi Kishan, please see below
      Thanks!
    • Kishan Konannavar
      Hello
      Could you tell what dynamic mesh settings are you using?
      Regards
      Kishan
    • barteo
      Hello I have the Smoothing (Diffusion) setting on, and the rest is described in my previous message above.
      I do not have any other setting on.
      Please advise. What settings would you recommend to move the piston (moving) wall?
    • Kishan Konannavar
      Hello
      Probably you would need to try layering setting. I would also suggest to check the profile text syntax. Check out the following links, maybe they could be helpful.
      7.8.2. Profile File Formats (ansys.com)
      " target="blank">ANSYS Fluent: Dynamic Mesh Problem for a Piston and Reed Valve - Part I - YouTube
      " target="blank">ANSYS Fluent: Dynamic Mesh Problem for a Piston and Reed Valve Part II - YouTube
      Isentropic Compression Simulation Example | Ansys Courses
      Regards
      Kishan
Viewing 5 reply threads
