March 28, 2018 at 4:54 pm
wbmckinney
SubscriberI was wondering if ANSYS is capable of modeling low-temperature plasma? If so, what modules or solvers would be used? Please let me know if anyone has any thoughts.
March 29, 2018 at 12:00 am
pgl
Ansys EmployeeIt depends on the pressure regime, are you talking continuous or molecular flow vacuum/pressure levels?
For continuous flow, ANSYS Fluent is a good choice. There are quite a few papers/article in the public domain where ANSYS Fluent is used to model plasma arcs. Most of these are high temperature plasma in that they have welding applications. Example.
At the other extreme, these folks used our simulation tools to model a plasma contained within the W7-X cryostat plasma vessel (PV). There's a paper published here by Elsevier. I'm not sure what blend of solvers they used, but either ANSYS Maxwell or legacy ANSYS Emag can be used to model charged particle traces. Some users have also simulated high vacuum by using a thermal solution analogy.
W7-X cryostat system are the plasma vessel (PV),
April 1, 2018 at 8:17 pm
April 1, 2018 at 11:53 pm
wbmckinney
SubscriberThank you for the reply. However, I do not believe these are applicable to my situation as I am trying to model low-temperature atmospheric plasma via dielectric barrier discharge through a tube.
December 28, 2018 at 5:39 am
Mostafa
SubscriberCan i use Ansys Chemkin in DBD plasma Simulation?
December 28, 2018 at 5:41 am
Mostafa
October 19, 2022 at 1:52 pm
Naman Tibrewal
SubscriberWhat module of ANSYS fluent will be used to simulate plasma impulse bits in space from propulsion thrusters? Please respond as soon as you can
5290
3311
2469
