September 20, 2023 at 7:55 pm
javat33489
SubscriberHi all. Colleagues, share your experience. How often do you use plastic (plastic properties of steel) when calculating metal frames using the beams and shells method? How necessary is this? I think we can get by with isotropic properties.
September 20, 2023 at 8:44 pm
Ankush Choudhary
SubscriberHi Javat,
It depends on the loading conditions. If the material remains below the yield stress, then its elastic properties are sufficient. However, if the loading exceeds the yield stress in the material, then it is better to use elastic-plastic material properties for the analysis.
For further information, you can check out this AIS course.
https://courses.ansys.com/index.php/courses/metal-plasticity/
September 22, 2023 at 6:32 pm
javat33489
SubscriberThanks for the answer. I saw this course. I was interested in people's experiences and their words. Thank you, it's clear now.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3151
1680
1470
