June 15, 2022 at 7:26 pm
zoiralli
Bbp_participantHello,
I want to get the contour plot of the principal total strain (elastic + plastic) or only the principal plastic strain, not the equivalent. I understand from the manual that the maximum principal elastic strain is EPEL1 and EPPL1 is the corresponding plastic. So I guess by adding them in an expression I will get the total. I also found P_STRAIN1 in the expressions available, but I can't find more about it in the manual; actually, there is no reference to that. From the attached picture it seems they have very similar plots and slightly different values.So my questions are:
Is it correct to use EPEL+EPPL to get the total strain, assuming there is no creep or thermal strain?
Thank you for your time.
3730
2570
1783
1236
594
