Plastic, total principal strain and P_STRAINuser-defined result for Mechanical.
    • zoiralli
      Bbp_participant
      I want to get the contour plot of the principal total strain (elastic + plastic) or only the principal plastic strain, not the equivalent. I understand from the manual that the maximum principal elastic strain is EPEL1 and EPPL1 is the corresponding plastic. So I guess by adding them in an expression I will get the total. I also found P_STRAIN1 in the expressions available, but I can't find more about it in the manual; actually, there is no reference to that. From the attached picture it seems they have very similar plots and slightly different values.
      So my questions are:
      What is P_STRAIN?
      Is it correct to use EPEL+EPPL to get the total strain, assuming there is no creep or thermal strain?
      Thank you for your time.
Viewing 0 reply threads
