May 6, 2022 at 12:20 pm
caoyangui1986
SubscriberAs shown in figure 1, the power supply path: VRM -- -- -- -- -- - where v0 N500745-1 -- -- -- -- -- -- AR_1P0_RF -- -- -- -- -- -- -- -- ICchip
as show Figure 2 shall i to generate an EXTENDED NET from N500745, 1V0, AR_1P0_RF
Figure 3. Following the wizard will automatically check these three networks for me
- The simulation results are shown as fig4
- the fig can refer to below
May 31, 2022 at 5:54 pmPraneeth
Kindly go through the following link for detailed information on PDN - Ansys Electronics 2022 R1 - Running Simulations.
All the very best Praneeth.
- Maxwell, HFSS or Q3D?
- Error
3736
2570
1783
1236
594
