October 3, 2018 at 7:10 pm
JASPERk
Subscriberi get the error Plot 'B_Vector_bottom' becomes invalid due to no available solution after analysing a geometry and wanting to plot the b field of a particular region.
What does this error mean? how can it be solved?
October 30, 2020 at 2:00 pm
NurAmirah1
SubscriberHave you find the reason behind it? I also have the same problem but with voltage excitation on electrostatic solution type. n -
November 2, 2020 at 1:34 pm
Navya C
Ansys EmployeeHi,ncan you provide some screenshots on how your setup and mode is and where in the region you want to plot the B fields?nThis way I can understand your problem better.nnRegardsnNavyan
- Maxwell, HFSS or Q3D?
- Error
2524
2064
1279
1096
456
