Plot Contact Tool Results Using Path for multiple load steps
    • Mirghani
      Hi Ansys Comunity
      Am trying to plot a graph of contact tool results vs path points for multiple load steps (10 Load Steps >>>10 Graphs) using the following command. however I managed to get the same graph but repeated 10 times. what's wrong with the command??.
      What will be the difference in the command if I want to do the following.
      1. Plot the results for different Load-steps.
      2. Plot the results for different Sub-steps.
      Command
      !!!Here I have a number of commands to define the path...etc.
      set,first
      *do,Loop,1,10
      /PBC,PATH,,1
      /REPLOT
      PLPATH,FS
      PLPATH,SD
      plnsol,cont,SFRIC
      plnsol,cont,SLIDE
      *if,Loop,lt,10,then
      set,next
      *endif
      *enddo
Viewing 0 reply threads
