October 5, 2018 at 11:26 am
Flo Henscheid
Subscriberhello, I need as a solution, the deformation of a point(node) depending on the time and the drag and lift forces on a surface. I know that you can spend the lift and drag forces in the setup but not how I can find them again or look at me when I calculate an FSI problem. I thank you once for your help.
October 5, 2018 at 11:34 am
Flo Henscheid
Subscriber*them
October 5, 2018 at 12:34 pm
DrAmine
Ansys EmployeeAre you asking for Fluid or Structural side?
October 7, 2018 at 5:07 pm
Florian Henscheid
SubscriberI found out how to show the deformations and so on at one point.
All I need is the lift and drag forces at one point of the solid
Best regards
Flo -
October 8, 2018 at 5:45 am
seeta gunti
Ansys EmployeeHello Florian,
Are you looking help on how to monitor the lift or drag at one point on a surface? Generally drag or lift is calculated based on either a plane or line where surface area is measured. And Fluent gives us the drag or lift on boundary walls. If you want these values on a derived surfaces, you need to write the UDF.
Seeta
2564
2080
1299
1106
459
