February 7, 2022 at 5:19 am
Rosmin_Elsa_Mohan
SubscriberHello Team,
I would like to plot the dispersion curve ( something similar to Figure 3(a) in the attached paper) for a gold nanoparticle on Sio2 model. Could you advice on how to model the dispersion plot in FDTD for a gold nanoparticle on SiO2 substrate? Is it possible to obtain dispersion from the absorption profile? Appreciate the advice.
February 8, 2022 at 12:00 amGuilin Sun
Ansys EmployeeYes, you can simulate the band structure. There are many examples: https://support.lumerical.com/hc/en-us/articles/360043165014
what you need is to choose one example that matches your device, modify its settings, in particular the period and the frequency range, as many parameters are set from "model", not from the groups.
Please try and let me know if you have questions.
PLease note that we use normalized frequency and k-vector points instead of the actual frequency and wave vector. so you may need to modify the script. But first let it work, then improve the result.
Trending discussions- Why am I getting “process exited without calling finalize”, and how do I fix it?
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5290
3311
2471
