We have an exciting announcement about badges coming in May 2025. Until then, we will temporarily stop issuing new badges for course completions and certifications. However, all completions will be recorded and fulfilled after May 2025.
Topics related to Mechanical Enterprise, Motion, Additive Print and more.
Plot Force – Displacement
    • mekafime
      Please, how I can get plot force (N) - displacement (mm)?
      At any point.
      Thanks
    • aramos
      You can use the chart to plot a force vs displacement.
      help link: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v191/wb_sim/ds_new_chart_table.html?q=mechanical%20chart
      Under Solution folder in the tree, create the Force and Displacement results. Once evaluated, select both of them with Ctr key and create a new chart.
      Use the detail view of the chart to edit the curves plotted and the axis of the chart.
      Best Regards
    • Sandeep Medikonda
      Indeed, as aramos pointed out, here is an article discussing this step by step.
      Sandeep
    • mekafime
      Thanks, but Force no mentioned, I think is Command APL.
    • Sandeep Medikonda
        Please see if this post helps?
      Sandeep
    • mekafime
      Thanks, is very useful, but I need in another point, no boundary.
    • peteroznewman
      Mekafime,
      You might have more success making your plot if you provide some screen snapshots of your model or if you Attach a Workbench Project Archive so we can show you how to plot what you want.
    • mekafime
      In this point, I need plot Force vs displacement.
    • Sandeep Medikonda
      In your force reaction, Change your location method to a geometry selection and select that vertex as shown below:
    • peteroznewman
      Hi mekafime,
      Here is an example:
      I think what you need is for the chart to have several values to plot.  To do that, setup the Step Controls like this:
      The setting shown will put 5 points on the chart.  Set the Minimum Substeps to 10 if you want 10 points on the chart.
    • mekafime
      Thanks so much !
Viewing 10 reply threads
  • The topic ‘Plot Force – Displacement’ is closed to new replies.
