January 10, 2023 at 3:22 pm
ixg90
SubscriberI have a simulation set up where I'm interested in plotting a quantity using the field calculator. I've saved an expression in the field calcualtor which outputs the integrated value of the Poynting vector on a particular surface in my model.
I'm able to manually use the field calculator to output this value for a given frequency. I would like to automate this so that a plot of formed for each point in the frequency sweep. So I'm interested in making a plot of Poynting vector vs Frequency.
Is this possible? I know there's a way to select "output variables" to create a plot, but when I click this box there are no output variables listed.
Thanks
- Maxwell, HFSS or Q3D?
- Error
2616
2098
1323
1110
461
