June 25, 2022 at 11:44 am
Catherine.antipuesto
SubscriberHi! I would just like to ask how to PLOT the phase reponse graph using Lumerical MODE? Thank you :)
June 27, 2022 at 8:47 pm
Guilin Sun
Ansys EmployeeIn both MODE and FDTD, you can plot the phase vs wavelength/frequency, vs space coordinate at a single wavelength, or vs a sweep parameter.
for 1D phase, you can use
plot(x,phase,”x”,”phase”,”phase vs x”)
here x can be wavelength/frequency/space-coordinate/sweep-parameter
for 2D phase, you can use
image(x,y,phase,”x”,”y”,”phase”)
where x and y are the same as above.
you may use matlab or other 3rd party tools to plot.
You can use pinch to remove singleton dimension.
A plannar frequency-domain monitor gives E/H/P as a function of x,y,z and wavelength/frequency. So in general the phase extracted from a monitor will have 4 dimensions, although one of the xyz will be singleton.
You can specify a particular dimension. Say you have a xy plane monitor. The phase will be
Phase(1:nx,1:ny,1,1:nf)
Using pinch to remove z singleton; phase=pinch(phase).
If you want to image phase or a specific wavelength, you can specify the frequency point, say fn (1<=fn<=nf), then
Image(x,y, pinch(phase(:,:fn)), “x”,”y”,”phase”);
June 28, 2022 at 10:35 am
SubscriberHello! How where can I get the "phase" data?
- Error on Lumerical device
3780
2587
1835
1244
600
