May 9, 2022 at 2:26 pm
dimitri.hamelin
SubscriberDear all,
I am doing an exercise with a beam in Transient structural after a modal analysis where I want to plot the deformation in the coordinate system of my fixed supportand not the global coorditate system (ie the deformation at the fixed support is always equal to 0).
May 9, 2022 at 3:15 pmViewing 1 reply thread- The topic ‘Plot the deformation in transient in an other coordinate system.’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
