Plotting a graph in fluent for Impedence vs Time
    • sherwin684
      How do we plot a graph using an expression in CFD post for transient state? I have created a point for which I need the data. I am able to plot the basic graphs like Temp vs Time. But I need Impedance vs Time. I have an equation to express impudence as a function of temp.
      Or can I export the values of the temp instead?
      Thanks in Advance!!
      Have a look at custom field functions (under the User Defined tab). Expressions aren't available for post processing in the current release.  Or export the temperature data. Note if you didn't create a file as part of the monitor there is no data, just a plot.
    • sherwin684
      Is is possible to export the temperature data from Fluent?
      I have created a point at the required location.
      What is the next step?
