Plotting iterations only after 100-200
    • atulsingh92
      How can I set or plot iterations of my mass flow at the outlet for example to plot only from 200 uptill the end of result.
      I want to do this because the global scale of y axis in a pressure plot, or mass flow plot, is absurd during the initial few calcualtions, I only want to look at them when it is reasonably closer to the convergence value.
      thanks,
      Atul
      Not sure you can set that easily: it will be possible but probably not worth the effort. If you open the Report > Plots you can change the y-axis scale after a while to have a look.
