September 10, 2019 at 5:57 am
gowtham1
SubscriberHi, I have created Geometry using Spaceclaim. Whe i click Model, the same is not getting openend in Mechanical as following error appears as PugIn Error. I have uninstalled and installed 3 times. Same error appears in ANSYS Student Workbench software... Please help
September 10, 2019 at 11:19 am
SubscriberPlease show a screen snapshot of the Geometry and the Outline-Structure from SpaceClaim.
The error says there are no bodies to transfer. Maybe you only have curves and no surfaces or solid bodies.
December 26, 2019 at 5:16 am
gowtham1
The error says there are no bodies to transfer. Maybe you only have curves and no surfaces or solid bodies. = Resolved. thank you very much
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2508
2064
1277
1088
456
