3D Design
3D Design
PlugIn Error Attach Failed
    • rogelio.perez
      I am using Ansys  (2020 R1) in two of my courses and several students are struggling to get geometry imported (either iges, step, Parasolid, or native CAD files).
      I see this error has been submitted and solved in previous postings. However, this time it seems to be a bug, since importing a CAD file worked fine for me, right after installation, but not afterwards (even with the same CAD file).
      Thanks for your help,
      Rogelio
    • RK
      Hi Rogelio,
      May I know what the error message is?
    • Keyur Kanade
      make sure you have installed in with 'run as administrator' option.
      make sure that you have write permissions to temp location.
      Are you importing in SpaceClaim?
      Keyur
