January 20, 2023 at 12:52 pm
Syed Husnain Tanweer Kazmi
SubscriberHello, hope you are well.
I am trying to evaluate a situation when a PMSM is running in open circuit generator condition and has a braking resistor also connected at terminal with switch between PMSM and generator still open.
At t=0 switch between braking resitor and terminals of the PMSM generator is closed.
I want to see the currents in windings resulting from this close of switch and hence effects like demagnetisation resulting from such a braking and while doing this I want to vary braking resistor vlaues to see the effects of parametric sweep on demganetization of magnets.How can I do this?
In the advanced motor training on this platform, there are demag exercise examples, can those be somehow applied to my situation?
Looking forward to some pointers.
Thanks alot.
- Maxwell, HFSS or Q3D?
- Error
2706
2146
1357
1144
462
