February 8, 2023 at 2:42 pm
Benjamin Walz
SubscriberHello.
I am trying to simulate the indoor air flow inside a room model.
More specifically, I want to calculate thermal comfort indices according to ISO 7730 (PMV, PPD and Draught rate).
How do I determine the local turbulent intensity or the variation of the air velocity, which I need to calculate the draught rate?
Is there an already existing UDF that I can use for that? Unfortunaely, I am not used to write C-Code.
Any help regarding this topic would be greatly appreciated.
Regards
Benjamin
February 9, 2023 at 10:29 am
Ansys EmployeeIt's the local velocity, so velocity magnitude that's used. You may also want to account for solar gain (heating) as that's a significant part of comfort.
Yes, there is a UDF, but as you'll know from reading the rules when you signed up I (as Ansys staff) can't share it on here. You may want to have a look on the Customer Portal; students may not have access but staff may if your site has a maintained licence.
February 10, 2023 at 7:49 am
Benjamin Walz
SubscriberHi Rob, thank you for your answer.
My current model does not take solar radiation (eg through a window) into account. I will model solar radiation in a later step.
The local velocity of air is used to calculate the PMV, but as far as I know, for the Draught rate I need a measure for local turbulence. I am slightly confused with the terminology here, since in german there is something called "Turbulenzgrad", which translates approximately to "turbulence intensity". Its defined locally as follows:
TU = 100 * standart deviation of velocity / mean velocity [%] This is how i measure turbulence in the laboratory. The measurements are used to "calibrate" my CFD-Model.
I found following equation in Fluent theory guide:
Tu = 100/u *(k*2/3)^0.5 ,unit is also % i guess.
Do these two expressions describe the same?
I do have access to the customer portal, I couldnt find something on this in Solutions. Can I ask for a hint where exactely to look for such a udf?
February 10, 2023 at 10:55 am
Ansys EmployeeI searched for PMV but I also have a staff level view so it may be slightly different. In the UDF I have I can't see any turbulence model values.
In the equation, you've got "k" rather than standard deviation of velocity, so you'll need to check the model definitions: the Theory Guide is fairly comprehensive.
3862
2639
1859
1254
600
