March 16, 2021 at 4:53 am
JH_Kim
Subscriber?????, https://support.lumerical.com/hc/en-us/articles/360034382494 , https://support.lumerical.com/hc/en-us/articles/360042328674-PN-depletion-phase-shifter ? ???? PN phase shifter? waveguide? refractive index? ?????? evanescent coupling(gap 250nm)? ???? ?????? ???? ????. ?? ??? 1550nm? ???? ???, DEVICE? charge simulation? ?? pn profile? .mat ??? ?????, ?? FDTD? NPDensityGridAttribute? ???? import ???, sweep? ?? drain? 0?? -2V?? 11 step?? ??? ????? ?????. ????, reverse bias? ??? ? ? waveguide? refractive index? ??? ??? evanescent coupling? ?? ??? ?????, ? ? waveguide? transmission ?? ??? ?????. ?? ?? ?? ??? ?? ????? ? ?????
March 16, 2021 at 8:37 amJH_Kim
Subscriber??????. npgridattribute index ??? ?????.nMarch 19, 2021 at 5:04 pmGuilin Sun
Ansys EmployeeWe are glad to hear that you solved the problem by your self!nViewing 2 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2656
2120
1345
1118
461
