August 4, 2023 at 3:19 pm
SAURAV GAUTAM
SubscriberI want to export electric field png image from monitor of around 100 simulation files.
Is there any script to automate it?
Thank you
August 4, 2023 at 6:19 pm
Amrita Pati
Ansys EmployeeHi Saurav,
You can use the exportfigure script command. You may specify the .png format as the full file name that you want it saved as. In the example link, .jpg is used but you can just replace that by .png. This can be done in a loop or the sweep utility depending upon how you are running these simulations. Please let me know if you have any further questions.Regards,
Amrita
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7626
4456
2955
1427
1322
