November 28, 2019 at 1:16 am
Deepesh
SubscriberHow to find Polar MI and Diametric MI in Ansys Workbench? and what is Diamteric Moment of inertia?
Thanks
November 28, 2019 at 3:59 pm
SubscriberDeepesh, I recommend you do a search on Google to find out what Diametral Moment of Inertia is. I found this in < 1 minute.
In SpaceClaim, you must assign a Material to a solid body, then on the Measure tab, click Mass Properties.
November 29, 2019 at 1:42 am
Deepesh
SubscriberSir, when we assign material in Spaceclaim, we get only moment of inertia to be seen in the details. -
November 29, 2019 at 3:12 am
SubscriberYou get three moments of inertia.
December 1, 2019 at 5:27 pm
December 2, 2019 at 12:31 am
SubscriberYou are showing Area Moments of Inertia because you have not assigned a Material in SpaceClaim.
There are two diametral MIs, and they have the same value when the object is a disk.
December 2, 2019 at 3:24 am
December 2, 2019 at 4:23 am
SubscriberThe units have changed too.
December 2, 2019 at 8:06 pm
Deepesh
SubscriberArea MI in the first photo has unit mm^5 whereas it should be mm^4??
Also, is there any other name for the diametral moment of inertia?
December 2, 2019 at 9:16 pm
SubscriberWith no material assigned, it's a volume moment of inertia and I don't care about that at all.
I only care about the mass moment of inertia that is computed after a material has been assigned.
December 9, 2019 at 9:07 pm
Deepesh
SubscriberSo, its basically before applying the material, it gives Area Moment of inertia?
After assigning material, it gives diamteral MI?
December 10, 2019 at 1:08 am
SubscriberNo, with no material assigned, it's a volume moment of inertia.
After assigning a material, SC gives three mass moments of inertia.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5290
3299
2469
