Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Poly-hexcore volume mesh with hexahedral cells upto domain boundaries
    • Karl Schoppmann
      Dear all,
      my task is to simulate the flow around an obstacle in a 3D domain described by a rectangular box.
      boundary conditions: 1x inlet, 1x outlet, 2x symmetry, 2x periodic
      surface of obstacle: no-slip wall
      My question w.r.t. Fluent Meshing (Watertight Geometry):
      I want to have a poly-hexcore mesh with polyhedral cells only in the vicinity of the obstacle and hexahedral cells anywhere else upto the domain boundaries.
      However, with poly-hexcore volume mesh settings, I get polyhedral cells at the domain boundaries.
      Is there any way to get hexahedral cells upto the domain boundaries?
      Thanks for your help!
      Forum Moderator
      You will, Fluent Meshing adds poly cells and then switches to hexcore away from the surfaces.
    • Karl Schoppmann
      So what can I do that Fluent Meshing creates a hexcore mesh directly at domain boundaries (not switching from poly cells to hexcore)?
      I want to have poly cells only around the obstacle, but not at domain boundaries...
      Forum Moderator
      You can't, that's how the poly-hexcore mesher works. Is there a reason for not wanting poly cells at the outer regions?
    • Karl Schoppmann
      For domain boundaries with periodic boundary condition and remarkable flow over these boundaries, I prefer to have a structured grid - in particular if the shape of the domain (in my case a rectangular box) allows to have hexcore cells upto the domain boundaries...
      Forum Moderator
      You can use Ansys Meshing and decompose the domain, but I generally just use a full poly mesh.
    • Karl Schoppmann
      Ok, thanks!
Viewing 6 reply threads
